I have a cam with a little surface rust from humidity. Still good to install?
Old Sep 13, 2009 | 02:29 PM
blue's Avatar
218/224 XE cam. A little surface rust from sitting in the basement. I think I'll buff it up and install it unless an expert says it would be a problem. What do you think?
Old Sep 13, 2009 | 04:30 PM
rclearyiii's Avatar
Clean Up The Journals
Just use some emory cloth to clean up the cam journals that ride in the cam bearings. It should be good to go then.
Old Sep 13, 2009 | 06:10 PM
NJ-LE's Avatar
Those Scotch-Brite or the green 3M pads from the supermarket are very good (and safe) for what you're doing.
Old Sep 13, 2009 | 06:16 PM
rclearyiii's Avatar
Agree NJ..those work well also...
Old Sep 18, 2009 | 07:42 PM
blue's Avatar
Thanks gents. It's going in the car. I took it to work and an old Dodge hotrodder looked at it under a magnifying glass and used a razor on the rust and he said it was good. I'm hesitant to use the green part of the scotch brite sponge though because I know it's abrasive enough to take non-stick off frying pans.
Old Sep 18, 2009 | 10:32 PM
rclearyiii's Avatar
Im sure it will work out fine Blue..good luck on everything.
Old Sep 19, 2009 | 10:00 PM
blue's Avatar
Thanks. It's in the car. My dad had a buffing set that I used. Cam looked good. I should have it running tomorrow. I did find out that it's a XFI cam since there is no XE cam with a 113 LSA like is engraved on it. So much the better, more lift.
97TA-WS6-Con
Feb 1, 2015 01:01 PM
smokin25th
Jan 1, 2015 09:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
