Hurst knob question
Hurst **** question
I bought a leather wrapped hurst **** and it won't fit on my short throw hurst shifter. The hole in the **** is too big for the shifter. It's on a 95 TA. Has anyone else had this problem or know of a way to fix it?
Re: Hurst **** question
Just a "shot in the dark", but a remedy might be to buy a 'Lou's Short Stick'. I would imagine that would fit the ****, but I would verify that before buying the 'Short Stick'.
My brother had the factory Hurst leather ****, and it fit to the "short Stick'.
What i did was cut the top 1inch or so off my stock shifter then drilled a hole in it and threaded to 3/8's coarse thread. That way i could screw my shift **** on the threaded rod part then put the threaded rod part on the shifter. It works fine and you can't tell the diff.
Originally Posted by thrift23
Was your hurst shifter stock or was it an aftermarket?
On the sticker under: SLP Engineering Installed Optional Content:
HURST 6-SPEED, SHORT-THROW SHIFTER
redz_02
Jul 24, 2002 09:42 AM
