humming sound when driving????
Old 03-25-2005, 10:56 PM
MiNuS-tWo's Avatar
ok well here is my problem. when driving my car it sounds normal and quiet, but when i get up to 60km/h a loud humming sound comes from the front of the car. it get louder the faster i go. the only time the humming sound stops is if i turn a right corner, but then when i straighten out again the sound comes back. what could it be, and i really hope its not too expensive or too hard to fix, or dangerous to drive with. thanks alot. i appreciate everyones help and oppinion with all questions i have asked.
MiNuS-tWo is offline
Old 03-25-2005, 11:52 PM
OBE1 95Z28's Avatar
Re: humming sound when driving????
Could be the tire tread; some tires make noise after they wear.
OBE1 95Z28 is offline
Old 03-26-2005, 09:06 AM
MiNuS-tWo's Avatar
my tires are fairly new, so i dont think that would be the problem. the sound only stops when im making a right turn not a left?????
Old 03-26-2005, 08:47 PM
Dwaynez28's Avatar
On the tire issue, you could swap the tires around and see if the sound moves--little bit of work i know. Dwayne
Dwaynez28 is offline
Old 03-26-2005, 09:07 PM
Bow94z's Avatar
Could be the wheel Hub. the part which is on the steering knuckle and has the studs on them...when the bearing goes bad they humm. just a thought
Bow94z is offline
F'n1996Z28SS
08-23-2023 11:19 PM
kksi
02-16-2015 06:49 PM
karnykamaro
02-02-2015 01:37 PM
squarehead
11-21-2014 08:02 PM
Quick Reply: humming sound when driving????
