How much does a broken stud cost to replace?
Old Jul 23, 2004 | 09:42 PM
TheV6Bird's Avatar
My friend broke a stud on one of his wheels. I know that studs need to be pressed into the hub. So what kind of labor and price is he looking at?
Thanks!
Old Jul 23, 2004 | 10:19 PM
Dave89IROC's Avatar
Re: How much does a broken stud cost to replace?
a couple of bucks for a new stud and nut
remove the brake caliper and rotor(or drum , depending)take a hammer(larger is good), hit the broken stud good and solid, it should pop out after one or two solid hits, then place the new stud through the rear of the hub, put a few large washers over the rotor side of the stud, put the nut on(backwards if feasable--flat to washers), hold the hub in place(screwdriver or similar) and tighten the nut, it will pull the stud into the hub
Old Jul 24, 2004 | 04:22 AM
ishz28's Avatar
Very east to do it yourself, heck, you might even want to upgrade to stronger studs while you're down there. The only thing I do different is, I use a small piece of wood to hit on.
Old Jul 25, 2004 | 08:14 PM
TheV6Bird's Avatar
Hmmmm, sounds easy enough. Too bad my friend just moved down to FL , and he is not mechanically inclined at ALL!! So he'll probebly bring it to a shop anyway.
I was always under the impression that studs needed to be pressed in by a shop?
Old Jul 25, 2004 | 08:25 PM
Dave89IROC's Avatar
at a shop, probably cost about a half hour, which up here is $37(hourly rate is $74)
Old Jul 26, 2004 | 10:14 AM
Hyperspeed97z28's Avatar
Hit it right on the head...
This is VERY VERY EASY TO DO !!!!
BPS
9
Mar 5, 2015 10:51 PM
dale3in98
Feb 14, 2015 12:18 PM
Catmaigne
Dec 25, 2014 12:16 PM
pologreen97z
Dec 2, 2014 10:42 AM
