how many miles are on your lt1
Old Mar 14, 2007 | 11:44 AM
fstenuf's Avatar
just like it says...for you higher mileage ppl please list what you have had to do if something broke or you had to replace something.
thanks!
Andrew
-i'm just wondering cuz i'm looking at buying another lt1 w/ 115k on it. mainly highway. my brother has one w/ a 107k on it and is still runnin like a champ. i was just curious about others.
Old Mar 14, 2007 | 02:21 PM
2000GTP's Avatar
My car has 94,500 miles on it. When I bought the car from the previous owner it had 93,500 miles and he kept all of his old service receipts. Aside from routing maintenance, the repairs done to the car included a new waterpump, a new catalytic converter, and an intake manifold oil leak repair. Since I took ownership of it, the only parts I had to replace were the power window motors and a battery.
Old Mar 14, 2007 | 03:31 PM
Terran2k's Avatar
~97,200, I really started racking up the miles after I moved here to texas. before I'd barely put 2k/year. I dont mind the miles though, I really dont plan to sell it. so as long as it holds together, Im gunna drive it.
Old Mar 14, 2007 | 04:51 PM
cn97z28's Avatar
Got just under 20k on my Z28 now, bought mine with just 12k on it. Its my sun shining weekend warrior.
Old Mar 14, 2007 | 04:53 PM
skibbez93z's Avatar
25k just turned not too long ago....
Old Mar 14, 2007 | 06:19 PM
MysticTeal95Z28's Avatar
M '95 has 107,2xx miles and runs damn good! My little bro has a '95 too with 15x,xxx on it and it runs damn good too! His pulls pretty hard I might add.
Old Mar 14, 2007 | 06:29 PM
Bert02SS
Guest
Posts: n/a
My '96 had about 97,000 miles on it when I sold it. It was leaking pretty good at the rear main seal. Ran well, though.
Old Mar 14, 2007 | 08:51 PM
reamo04's Avatar
94 w/ 147k on the clock and still running strong.
only have had to do basic maitenance, tranny got rebuilt at 123k because it over-heated.
only major problem ive had, is a rear-end pinion seal leak, and a sticky lifter that fixed itself after an oil change.
Old Mar 14, 2007 | 08:56 PM
Spllouder's Avatar
78,xxx on my 1994 LT1 , One Owner ME ! . Runs Strong
the 3.4l btw has 90,000 on it and i just replaced its water pump
Old Mar 14, 2007 | 09:11 PM
sandman63's Avatar
71,000. Nothing but a leaking water pump.
Old Mar 14, 2007 | 09:17 PM
shock6906's Avatar
122k. The only thing that I have personally replaced is the water pump and plugs/wires. I did that shortly after buying the car at 108k miles.
Old Mar 14, 2007 | 09:42 PM
JeffsWorld's Avatar
17,655mi on the clock. I had both door windows replaced under TSB back in '97, my window motors are dying a slow death and have the infamous intake manifold oil leak (but I drive it so little, that I am not too concerned).
Old Mar 15, 2007 | 09:44 AM
hawk29's Avatar
33K on my 95 bought with 13K in 97
Old Mar 15, 2007 | 02:02 PM
Z28SORR's Avatar
Bought used with ~52,000m on it, now ~79,000m. I have repared or replaced: Shift Boot Assembly, Rear Window/Panel(convertible), both Visors, Fan Belt, Small Radio *****, Oxygen Sensors, Water Pump, Divers Window Motor, Adjusted Drivers Side Window, the Right Rear Turn Signal Light Socket(corrosion). Because it's a convertible and has leaked I will be replacing the driver side seat cushion and all seat covers. Will need a new top soon?
However the previous owner had these problems:
Plate, instrument panel trim-center. Replaced. 13m
Glass, windshield. Resealed. 4378m
Window, defog wiring. Replaced. 4378m
Front seat belt retractor. Replaced. 4378m
Manifold and/or gasket, intake. Replaced. 5468m
Glass, front door-right. Alignment. 13515m
Actuator assem., rear compart. lid. Replaced. 13515m
CD player, 12 disc rear. Replaced. 13515m
Bow assem., no. 1. Replaced. 13515m
Hub, crankshaft. Replaced. 29603m
Sensor, mass air flow. Replaced. 30158m
Pump, and/or gasket, coolent. Replaced. 30158m
Cover and/or gasket, timing. Replaced. 30158m
Crankshaft. Replaced. 31748m
Sensor, oxygen. Replaced. 31892m
Air pump kit. Install. 35586m
Gasket, cylinder head-right. Replaced. 35586m
Engine, universal. Replaced. 37670m
Finally had enough and traded it for a Mustang.
So the car has ~79,000m but the engine only has ~14,600.
Old Mar 15, 2007 | 02:22 PM
CheshireCat's Avatar
150K on the odometer...
2 starters
AC compressor and associated parts
2 water pumps
1 radiator
I replaced the opti, plugs and wires at around 115k just because I was replacing the water pump and was basically there...
