How long before emissions tested again?
Old Dec 14, 2005 | 09:02 AM
Jazsun's Avatar
I just emissions tested and i passed, how long is it until I have to go again? I am asking cuz I am thinking about going to offroad y-pipe.thanks
Old Dec 14, 2005 | 10:20 AM
2000GTP's Avatar
Re: How long before emissions tested again?
Every two years. If I remember correctly from some of your other posts, you are from IL too correct? The off-road y-pipe may give you some trouble the next time around when you have to go for emissions unless you plan on swapping your stock and non-stock y-pipes back and forth.
Old Dec 14, 2005 | 11:21 AM
Jazsun's Avatar
yea I live in IL. I know I cant use the offroad pipe for emissions, I plan on swamping them out. Does your ORY fit good w/ your catback? I have the same one, and want to use clamps so I can remove it.
Old Dec 14, 2005 | 02:24 PM
2000GTP's Avatar
Actually I am using the Pacesetter ORY y-pipe that is used with the Pacesetter long tubes so it is a little different then your style. However, it mated perfect to my Magnaflow exhaust. The I-pipe was slight oversize and it slid right over the y-pipe and I was able to seal it tightly with a 3" band clamp.
Magenta_Hearts
Mar 25, 2015 10:24 AM
naaz90
Jul 27, 2002 08:22 AM
