How do you take the pass airbag out?
What the easest way to take it out?
You have to take out the entire dash. It is really not as bad as it sounds though.
Originally Posted by Sinister95Z
(Post 5221429)
Basically, my car is steet legal, but I only bracket race with it. What is the weight, 5 pounds maybe? WD |
I think its more than that like 15lbs
Originally Posted by The Engineer
(Post 5221532)
WD |
the plastic cover on the dash DOES NOT have to be removed the one that says air bag, I just did the one in my 95 bbc project was removing the hvac and removed the air bag while the dash was loose not out, the top dash pad is very brittle be carefull one bolt at the bottom of each side of the dash (has ground wires on it) lots of little screws at the top ,one behind the console.it has lots of wire retainers hooked to it the whole air bag and metal bracket sort of roll out with the dash leaned forward, total pain in the ars
did mine without taking the dash out, but it's a pain in the a$$. Better have some patience. Also changed driver side to grant gt wheel.
How much weight did you lose with both bags?
honestly don't remember, but can weigh both as I still have them laying around. The grant wheel is alot lighter than stock with a bag though. also took off cruise, abs and changed driver seat to manual from power.
