how do you get the "change oil" light to go off?
Old Jun 21, 2006 | 08:48 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
just what the title says..i used to know... but forgot.
for car in sig
thanks!
Jared
Old Jun 21, 2006 | 08:51 PM
94_PatriotRed_Z's Avatar
Re: how do you get the "change oil" light to go off?
turn the key, but dont start the car, then push the gas pedal down 3 times hold it on the 3rd time, then when you let go the light should blink letting you know it is reset.
Im not sure if thats how it works on f-bodys(my car doesnt have a light) but I know Chevy trucks are that way
Old Jun 21, 2006 | 08:57 PM
MyShibbyZ28's Avatar
If that way doesn't work, disconnect the battery and see if that does it.
Old Jun 21, 2006 | 09:52 PM
...or read the owner's manual...
Originally Posted by owner's manual
How to Reset the Oil Change Light
The GM Oil Life System calculates when to
change your engine oil and filter based on vehicle use.
Anytime your oil is changed, reset the system so it
can calculate when the next oil change is required. If a
situation occurs where you change your oil prior to a
OIL CHANGE light being turned on, reset the system.
After changing the engine oil, the system must be reset.
1. Turn the ignition key to RUN with the engine
turned off.
2. Press the TRIP/OIL RESET button located on the
instrument panel for 12 seconds. The OIL CHANGE
light will start to flash to confirm that the system is
reset. The reset is complete when the OIL CHANGE
light goes out.
Old Jun 21, 2006 | 10:03 PM
myslowcamaro's Avatar
shoebox's quote is correct, but sometimes after you hold in the trip reset for 12 seconds, you have to turn the key back as if you were taking it out, noticed this the other day when it kept coming back, i did the reset, but started the car immediately, it came back shortly after until i turned the key back
eazyZ
Mar 1, 2015 07:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
jj71787
Jan 31, 2015 10:20 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
