How do I remove rear garment hooks?
Old Mar 5, 2005 | 12:29 PM
magnumv8's Avatar
I am trying to remove the trim panel in the back which has the garment hook on it. I have popped the little plug on the hook, but it only comes out a little. I thought this would pop out and there would be a screw behind it, but I cant get the plug out. I didnt want to break anything so I thought I would ask here.
thanks
Old Mar 5, 2005 | 12:31 PM
BadCo.'s Avatar
Re: How do I remove rear garment hooks?
You just have to keep gently trying to either get that plug out (I think they come out completely on our cars) or it will flip down out of the way. Then you can get to the screw that holds the hanger on.
on second thought if I remember correctly that "plug" is the type of fastener that is what holds the hanger on. just kinda work it out gently. Try a squirt of mild dishwashing detergent in there or somethign to lubricate it a little ...perhaps.
Old Mar 5, 2005 | 12:38 PM
magnumv8's Avatar
it pops out about 1/8 inch very easily, but then doesnt want to move. I tried both sides, and have pried with a screw driver, but they dont seem to want to move. I will try lubricating it and see if that helps.
the reason for this is that I am trying to access the shock mounting bolt. This is the panel that has to come off right??
Old Mar 5, 2005 | 12:45 PM
BadCo.'s Avatar
Im pretty sure they wont come out easy because the plastic piece your trying to remove has ridges of sorts, I dont know the name of the type fastener it is (sort of like a zip tie in a way as they go in easy yet dont want to come out or go the other way) your going to have to apply a little more force...and use a rocking motion along with a lubricant should help...try a pair of pliers using a scrap of t shirt where the pliers grip or something so you dont mar the plastic piece
Old Mar 5, 2005 | 09:30 PM
KPZ-28's Avatar
If you do break it the gm part number is #10159119 and it costs about $5.68 from a dealer.
Old Mar 5, 2005 | 11:40 PM
Mean Green Z28's Avatar
Just pull the center tab out as far as it comes and then pull the whole hook and it would come right off. There's no screws in there. Just the hook with a split back end and the plug to make it stick in the hole, just like regular trim clips on imports.
Jan 3, 2015 07:22 PM
squarehead
Nov 21, 2014 08:02 PM
Anderson
Jul 28, 2002 10:57 AM
