How do I remove the parking brake handle?
Old Jun 10, 2004 | 01:23 AM
Schantin's Avatar
I'm installing a Pro 5.0 shifter tomorrow, so I need to remove the center console. So, I need to remove the parking brake handle. I looked at it and could only see a single rivet. Is that the connector? How can I get the handle off before removing the center console?
( I would just pull the console up over the handle to remove it....did that on my 97 Z, and scuffed the parking brake handle BAD I don't want to repeat that mistake!)
So, any help would be greaty appreciated! Thanks in advance
Schantin
2002 Camaro Z28 M6
PS...I'm new to Hawaii (definetly not the same as Texas). Any good LS1 shops on the island of Oahu? This info would be awsome as well
Old Jun 10, 2004 | 03:09 AM
AL SS590 M6's Avatar
Moderator
If you crawl in from the passenger side and look beside the brake lever you can see the dog that engages the cable to the lever. If you take a small screwdriver and hold the dog from engaging then you can pull the brake handle all the way up so that pulling the console is easy.
Old Jun 10, 2004 | 10:36 AM
tom2's Avatar
Have no idea and shouldn't post, but normally this type of stuff is designed to just push on with a couple dogs to hold it. If there is no outside fasteners, try slipping a thin strip of some kind up from the bottom of the grip on each side and unhook them. Might pull off.
737drivr
Feb 20, 2015 11:54 AM
Matt-01-SS
Aug 2, 2002 04:05 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
