Which hoses for heater core flush???
Old Mar 11, 2011 | 04:20 PM
Z28avalanche's Avatar
Please forgive me it's my first time dealing with the no heat issue. I'm sure this has been asked before, but I'm not quite clear on what two hoses need to be flushed. Is that the only place I remove the hoses is at the water pump? I read shbox instructions, I just want to be clear on the proper hoses to flush. BTW where is the heater core located?
Old Mar 11, 2011 | 07:03 PM
Chevyssoccer's Avatar
Re: Which hoses for heater core flush???
its in the firewall. the two hoses will be the only ones that go that way.
Old Mar 11, 2011 | 10:06 PM
It's pretty hard to miss the hoses that go back to the firewall. It's the two small hoses/pipes from the pump on the passenger side.
http://shbox.com/1/heater_hoses.jpg
http://shbox.com/1/lt1_water_pumps.jpg
Old Mar 13, 2011 | 03:12 PM
Thanks for the help. I'm going to flush the heater core the first chance i get. Do I have to drain the radiator when flushing or can I just flush the heater core and then refill the loss of coolant and bleed the system?
Old Mar 13, 2011 | 09:59 PM
Draining it might be neater in the long run, but you can do it either way. You can't avoid some mess by the hose flushing.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
