high beams won't work, questions??
Ok I did a search on here and couldn't find what I was looking for. My high beams will barely come on. I can keep fiddling with them and I can eventually get them to come on. It usually takes as much effort to get them back on low beams. Do you think I need to replace the dimmer switch or just adjust the rod? If I need to adjust the rod how do you do it?
lights
does you steering wheel rock back and forth (from left to right). If so, then the switch schould work fine when the wheel is tugged to the left. Sounds cheesy, but it happened to me.There must be a bushing in the column that goes bad and gives it just enough play to mess up the dimmer.
ChrisFrez
Dec 15, 2014 03:09 PM
