Hi all ABS problems in Denmark
I need a Standard Motor Products ALS317 ABS Wheel Speed Sensor - w/TRACTION CONTROL for my Chevrolet Camaro 1997 5,7 the car's VIN is 2G1FP22P7V2108352
I need the right and left rear, and I can not find anyone who has it in stock maybe you can help me?
I can see that the Standard Motor Products ALS318 ABS Wheel Speed Sensor looks the same as als317, but can I use als318 it instead of als317 or what is the difference between these two or is there another one I can use instead of als 317 ?
I have a car to 19000.- usd because of car tax in Denmark on 180%
I can not drive the car because of the law of Denmark abs brakes must work 100% real
so it's important to me so hope you can give me an answer
regards
Peter Skov Pedersen
Denmark
regards
Peter Skov Pedersen
Denmark
Re: Hi all ABS problems in Denmark
Welcome to the Forum.. I can not find out anything official. However I did find 2 forum threads that said the LS1 1998 wheel sensor " ACDelco 10456535 Rear Wheel ABS Sensor " can be used as a replacement. I believe that sensor is also the Standard Motors ALS318.
The threads are : Need help finding a replacement speed sensor - NJFBOA - Home of New Jersey's Camaros and Firebirds and Need help finding a replacement rear speed sensor - 95 Formula w/ traction control - The BangShift.com Forums
Many thanks for the link you posted but I did not quite get an answer on whether the called ALS 318 can be used without problems
but many thanks for your answer
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
