Hey, where is the low pressure cycling switch located?
Old Jun 18, 2004 | 06:26 PM
warwickbass's Avatar
I need to short out the terminals to turn the A/C compressor on.
Old Jun 18, 2004 | 06:48 PM
indieaz's Avatar
I was just about to post the same question. Anyone know?
Old Jun 19, 2004 | 01:31 AM
Lower's Avatar
I found reference in A/C posts to jumpering a red and grey wire, and then noted that the electrical connection going to the high pressure side contained wires of this color.
However, I didn't dare jumper something without confirmation and I don't suggest that you do either!
What I can tell you is that if you have a guage hooked up to the low pressure line, and the compressor is off, your gauge will show a TON more pressure.
My example was that while the compressor was on I was reading about 35 psi, but when it was off I read about 220 psi. I know this doesn't help if your readings aren't normal to start with, sorry!
Old Jun 19, 2004 | 09:00 AM
Should be the red/black and grey wires are the two that you jumper on the connector. The sensor is on the a/c pipe right at the RH shock tower.
meissen
Jun 1, 2015 07:59 AM
DetroitZ28
Feb 13, 2015 07:33 AM
94Form
Feb 10, 2015 11:23 PM
pologreen97z
Dec 2, 2014 10:42 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
