Help needed??
Old Jun 15, 2004 | 09:02 PM
slo99SS's Avatar
Help needed??
How do you adjust the headlights? I just need to know how you aim them so they point at the right level and angle?? I have a 99 camaro SS if that helps.
thanks
Old Jun 15, 2004 | 09:41 PM
SSpdDmon's Avatar
There are a couple bronze-colored "star" bolts on the headlight assembly. By turning them clockwise/counterclockwise, you can point the headlight up/down and left/right. I didn't have a specific socket for the star bolt, so I just found the best one that fit and carefully adjusted mine to where I wanted them. Don't forget to look for a flat surface a few feet away from a wall so you can get 'em aimed appropriately.
Old Jun 15, 2004 | 10:49 PM
slo99SS's Avatar
so the torx head bolt adjusts vertically AND horizontally?
Old Jun 15, 2004 | 11:59 PM
SSpdDmon's Avatar
I meant there are two torx head bolts on each assembly. One adjusts the verticle aim (up/down) and the other adjust the horizontal (left/right).
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
