Help with AC Pressure Readings
Old Aug 25, 2016 | 12:21 AM
MarkC's Avatar
Does someone know what engine RPM the published "A/C Performance Chart" is based on for taking refrigerant readings?
I think my AC is a bit low on refrigerant--as my air could be colder and my compressor seems to be cycling a bit much. I have a refrigerant manifold to perform a pressure test, and I found the specs for high and low pressure vs ambient temp...but in all my searches, I couldn't find what the appropriate RPMs are for the "A/C Performance Chart."
Thanks for any help...
'97 Camaro Z28
Old Aug 25, 2016 | 07:02 AM
GaryDoug's Avatar
Prominent Member
Re: Help with AC Pressure Readings
It's at engine idle speed, but not specific. Another page says to have the engine idling for 20 minutes before starting diagnostics.
Old Aug 25, 2016 | 11:24 AM
MarkC's Avatar
Perfect--just what I needed to know--Thanks!
Old Aug 25, 2016 | 11:51 AM
RiverMutant96's Avatar
Yeah Marc,
I charged my 96 just last Sunday and with a 72 degree day, the pressure would be 35-45. I did also have the engine idling for about 10 minutes & kept the air on max cool. Now it seems to pumping real cold again!
eagle54348
Jun 15, 2015 05:00 PM
alex5366
Jun 14, 2015 10:31 PM
warmeck
May 31, 2015 11:29 AM
Hobbyguy
May 26, 2015 02:15 PM
LimitedEd1LE
May 18, 2015 01:24 PM
