Heater isn't hot 94 camaro
Old Apr 25, 2004 | 08:00 PM
crazy_jackalope's Avatar
My heater doesn't really work in my 94 z28. It blows air slightly warmer than the outside temp. Any help or suggestions would be appreciated, thanks
Old Apr 25, 2004 | 08:09 PM
Rice Killer87's Avatar
does the car get up to operating temp.?
Old Apr 25, 2004 | 09:11 PM
94blackz14.2's Avatar
You need to flush out your heater core because it is more than likely clogged up. My heater never worked for the first three years I owned it until I flushed the heater core about 7 months ago.
Old Apr 25, 2004 | 09:33 PM
Yep, flush the heater core. Remove the hoses at the water pump and flush both ways with a garden hose. Keep any water off the opti. You might be surprised at the gunk that comes out.
Old Apr 25, 2004 | 09:43 PM
Pandamonkey's Avatar
Are you low on coolant?
Is your water pump leaking?
Old Apr 25, 2004 | 10:02 PM
I don't think I have any leaks I'll try flushing my heater core. I'm not too worried because it is warming up but I definitely want it for the winter.
Old Apr 25, 2004 | 11:31 PM
Another benefit of flushing it out is that any gunk that settles in the core will accelerate corrosion and rust through. So heat is not the only issue.
Jlo
Feb 3, 2015 09:41 PM
Britbilly
Jan 7, 2015 08:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
