Is this the heater core?
Just this morning, I started the car to go do some grocery shopping. I had no hot air coming out of the vents while in defrost. Is this a problem with the heater core?
Re: Is this the heater core?
find both of the heater hoses that are goin into the firewall, after that (with car warmed up) grab the hoses
1. if one of them is hot and the other is cold then your heater core is stopped up
2. if both of them is hot and still no heat from any mode on your HVAC module, then i would say your heater core
3. if both of you hoses are cold then check something like a thermostat being stuck closed, or insufficient coolant in radiator
then tell me whats up with them if you need some help
ducttape1975
Jul 10, 2015 06:29 PM
