headlights not working
Old Feb 3, 2015 | 07:35 PM
94Z28LS1toLT1's Avatar
hey guys my headlights dont turn on,so right now im driving with the lower ones on the grill,i already changed the headlight switch, i dont think the lights can be burned out,they both just stopped working outa nowhere. Is there a fuse or relay i can look at?
Old Feb 3, 2015 | 08:49 PM
GaryDoug's Avatar
Prominent Member
Re: headlights not working
First, check the high beam lights.
If they work, the low beams are probably burnt out.
If they don't work, the problem may be with the fusible link #2. That is one of the fusible links at the power terminal next to the battery on the fender well. You can try wiggling them around while the light switch is on and may find out which one feeds the lights that way. It may flicker the lights on and off when you move the right one. Fusible links must be replaced and can be found at most auto parts stores. You need to buy a a matching size.
http://shbox.com/1/fusible.jpg
Old Feb 3, 2015 | 10:43 PM
You might be surprised how many people have had both lights go out at the same time. Check the power and ground at the bulb socket.
Old Feb 10, 2015 | 10:19 AM
Thank you guys turns out i just needed to tap the light bulbs and now they work thank u guys
ChrisFrez
Feb 15, 2015 08:12 AM
Brake_L8
Jan 20, 2015 09:44 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
