Headlight problems.......please help???
Old Nov 6, 2006 | 12:14 PM
DB75's Avatar
The high and low beams do not work on my '95. The running lights, fog lights brake lights, and turn signals all work fine, though. The last time the car was driven was about two weeks ago and I remember them working fine then. I don't know if this has happened to anyone before but I find it hard to believe that all four lights would simultaneously crap out on me. Could this be a wiring problem possibly somewhere in the harness? And if so what's the best method of tracking down the problem. I flipped through the owner's manual only to find out that the lights aren't linked to a fuse in either box. Any info is greatly appreciated.
Old Nov 6, 2006 | 01:12 PM
NEWBIE T/A's Avatar
Question Check the circuit breaker ?
Shoebox's site to the rescue once again !
Main site is here:
http://shbox.com/1/4th_gen_tech1.html
More specifically, look here.
I see there is also a fusible link - not sure how you check that other than for continuity w/ a meter, or in really blatant cases , look for the burned cover.
If none of the above , then I would look towards the headlight switch itself.
Good Luck !
Britt
Old Nov 7, 2006 | 07:39 AM
DB75's Avatar
Thanks NEWBIE T/A but I can't read the text on the diagram. All four lights inside the headlamps don't appear to be blown, either. Anyone have any other suggestions?
Old Nov 7, 2006 | 07:55 AM
NEWBIE T/A's Avatar
Lightbulb Hmmm ....
Perhaps this will help.
Britt
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
