Headlight motors going bad?
so now every time i turn on my headlights they don't come on. i have to turn them all the way off and back to the on position for them to pop up. what's the deal?
Re: Headlight motors going bad?
Is it one or both?
You say they don't "come on" -but is it that they don't light, or just that they don't raise?
Do they close OK?
Do they make any grinding sound?
If they don't light, just check the plug connections. Unplug them if needed and look for corrosion.
If there is no grinding noises and if they are simply not opening, you might want to try doing something like this headlight opening fix. With a little bit of tape, you can test this out to see if it helps, and then make the "big purchase" of tubing for less than $1.
If you do have grinding, and or the headlights come up at strange times, then carefully read through this, from Brent's site. Be sure to go all the way down to the "FREE Headlight Fix" portion, if you'd just like to have a go at a "trial" fix.
Do they close OK?
both of them do not pop up. but they always do on the second try, with no grinding. i will check out the first link more closely. seems like the fix. thanks.
ChrisFrez
Feb 15, 2015 08:12 AM
