Headlight keeps burning out
Old Oct 24, 2011 | 07:48 PM
94greenta's Avatar
Ive replaced my passenger side low beam 3 times in a month on my 2000 WS6. Has anyone has this issue and know what causes it? I ran a new wire(power) for the headlight(about 3 ft back in harness) because they have an issue with corrosion. I just wonder what could cause this.
Old Oct 25, 2011 | 09:07 AM
96 Z 28's Avatar
Re: Headlight keeps burning out
Check for leaks/cracks.... I bet their is moisture getting in, and this is causing the bulb to blow.
Old Oct 29, 2011 | 10:58 AM
Chevyssoccer's Avatar
How is your battery, lower voltage can causes thigs to run at higher amperage, similar to how the corrosion can add ressitance to the circuit... same result bulb burns hotter and doesnt last as long.
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
