CamaroZ28.Com Message Board
-   General 1967-2002 F-Body Tech (https://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/)
-   -   header gaskets, and getting headers coated (https://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/header-gaskets-getting-headers-coated-881978/)
94Z28LS1toLT1 Mar 16, 2015 08:56 PM
hey gang i have a header leak was gone for 3 months, now it but came back turns out my mechanic used the wrong header gaskets, he used mr.gasket ultra seal seal ones,went to a muffler shop and they told me they can fix it but they will use special ones made for headers i believe they are aluminum/copper ones made for headers.
heres a another catch they will put new bolts,change the gaskets,and get my headers coated to silver,and get the rust out too. total cost is 800 to 1000 for that work,is that too much or should i look somewhere else? ive gotten work done before by them and there reviews are prett good too. its called "The best muffler shop":think:
thank you guys
FredM Mar 16, 2015 09:14 PM
Re: header gaskets, and getting headers coated
I am header shopping and that isnt a great deal but not a terrible deal. I see it as replace gasket and go, not any where near 800$. But you getting everything done, it still seems a bit high since your supplying the headers. Also you might want to look into what kind of coating. Other guys here probably know better.
Injuneer Mar 16, 2015 09:26 PM
Were the Mr Gasket the ultra-seal copper? If so, why are they the "wrong ones"? Are they the D-port ones for the LT1? I've had those on my stroker for 14 years with no leaks. Sounds like the header flanges may not have been checked for flatness before they were installed.
The cost will depend on how complex the removal is (e.g. - is anything welded), how badly they are rusted, the type of coating to be used (e.g. - cera-metalic, like Jet-Hot, applied both inside and outside of tubes), whether the Y-pipe will be coated, etc.. $1,000 sounds very high. Why not do the removal and reinstall yourself?
94Z28LS1toLT1 Mar 17, 2015 01:54 PM
hey guys thank you for the replys. FredM,the total price for gaskets,labor,and getting them coated is 800 even,
Injuneer my mechanic used the mr.gasket but not the ultra seal copper ones these ones are like paper. they are gonna use the ceramic metallic coating for mine,and they are gonna do it inside and out.,the y pipe is getting it too,and the guy mentioned too hes gonna install the ultra seal copper gasketss
Injuneer Mar 17, 2015 04:08 PM
Make sure someone checks the flanges for straightness and flatness, or even the best gaskets may not seal.
94Z28LS1toLT1 Mar 17, 2015 08:19 PM
thank you will do Fred i appreciate it:D
Justin@Entropy Mar 20, 2015 03:03 PM
The stripping of the rust on/in the headers costs as much or more than the coating
94Z28LS1toLT1 Apr 6, 2015 09:10 PM
Hey guys just got the car back and it's perfect way better air flow no ticks or leaks smooth as he'll thank u guys headers look beautiful
FredM Apr 7, 2015 05:37 AM
Nice, now you have the whole spring and summer to enjoy it. Congrats
