grinding noise from the back of car?
Old Nov 24, 2011 | 10:27 AM
englundjd's Avatar
I was driving around last night and i noticed a (metallic?) grinding noise coming from the back of the car. I could only hear it when i accelerate from 1000 to 3000 rpm (or anywhere between the 2 figures) and then i'd hear it up until i stopped. so i was thinkin somethin was hung up somewhere. Then after a little bit of trying to figure it out i went out again and it did it when i was at a stop. Would this be a fuel pump?
Old Nov 25, 2011 | 05:26 PM
ShowOff67's Avatar
Re: grinding noise from the back of car?
Any grinding sound i ever heard comming from the back of the car had something to do with the brakes. if the fuel pump was going bad you would notice strong loss of power even the thing even starts.
Old Nov 25, 2011 | 06:12 PM
Ocala93TA's Avatar
A guess sounds like brakes , no way a fuel pump makes a grinding noise
Old Nov 25, 2011 | 11:45 PM
Originally Posted by englundjd
...... Then after a little bit of trying to figure it out i went out again and it did it when i was at a stop. Would this be a fuel pump?
If it made the noise while the vehicle was at a stop, I wouldn't think it was the brakes or the rear end.
Old Nov 26, 2011 | 11:45 AM
englundjd's Avatar
Injuneer: yea thats what really threw me for a loop. im going to adjust my breaks just on the off chance i was hearing things 0.o it was loud enough that my girlfriend even noticed it.
ive driven the car to town and around town then back home and it doesnt do it very often which is even weirder
Hope you all had a good thanks giving!
who ever moved this, Thanks
Old Nov 26, 2011 | 01:34 PM
RUDEDOG's Avatar
Could be a u-joint going bad. The disc brakes are not adjustable. You might need to change the differential oil and LSD additive.
Old Nov 26, 2011 | 05:04 PM
englundjd's Avatar
Rudedog:
got under the car yesterday and checked the driveshaft. the U joints dont seem to look worn or have any play in them.
I jacked up the rear end again today also and i turned the tires by hand for a while to see if i could get it to make that noise but i got nothin, how hard should they turn in nuetral? it was almost a workout to turn them for a few minutes.
Old Nov 26, 2011 | 05:05 PM
englundjd's Avatar
how do you check/ change the fluid in the rear end? ive never really messed with any kind of rearend
Noenav
Mar 1, 2019 07:38 AM
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
