Good idea for a couple extra horsepower?
Click
Seems like a good idea to me to gain a few extra horses
I don't see that it could hurt anything. What are your opinions? I know I could do it for about $10.
Re: Good idea for a couple extra horsepower?
Originally Posted by 93LT1355
I don't see how you could gain horsepower. The engine is still driving the pulley.
also technically you wouldnt gain any hp... you are just redirecting it from the alternator to the rear wheels.
Originally Posted by JoeliusZ28
thats an interesting concept. does anyone have any wiring schematics for a DIY job??
Originally Posted by L31stang
I can get on All Data at work monday and figure out what needs to be done then I'll post it up!
it's a simple hookup...
the only part ii'm not 100% sure of is the poles on the relay.
all you need is a throttle trigger switch from a nitous kit, run a line to a relay. when the throttle triggers the switch, it engergizes the relay, disconnecting the outlet wire on the alternator.
not having a relay or schematic in front of me....it's hard to imagine and describe.
the switches are about $10-15 i think, then a cheap relay and some wire.
the manual version would just be to have a one way switch wired into the oulet of the alternator. when it's on, it functions as normal. off the alt is disconnected.
I wouldn't do it. You want your PCM to have max voltage at WOT or you can have other things affected that will kill power. My buddy added a volt "Blaster" to make his car give more juice at WOT. Heck my car would drop to 12.8-12.9 volts at WOT with the alternator hooked up. That starts to hurt fuel pressure and cause a loss of voltage at the sensors like TPS. There are better ways to make HP.
Using a 5 prong relay numbered 87, 87A, 30, 85 and 86 and a nitrous style WOT switch.
Relay 85 - Battery +
Relay 86 - WOT Switch (other terminal on WOT switch goes straight to ground)
Relay 30 - Harness side of small red wire
If WOT switch is normally open connect small red wire on alternator to 87A
If WOT switch is normally closed connect small red wire on alternator to 87
I doubt battery voltage would drop down low enough to affect anything in a 13 second 1/4 mile run.
Originally Posted by RobbyRob
How is this suppost to help?
