going to higher octane
Old Nov 23, 2004 | 05:22 PM
Black02Z's Avatar
Just got an 02 z the woman that had it earlier was using reguler unleaded its got 38 thousand miles and im going to a higher octane
now my question is how would i go about doing this and should i check for anything that could have gone wrong from this
Old Nov 23, 2004 | 05:31 PM
unvc92camarors's Avatar
Re: going to higher octane
well, it will automatically adjust to the higher octane
not sure really how you could check to see if any damage is done
i'd suggest running some seafoam in it though to clean out anything in it
Old Nov 23, 2004 | 05:38 PM
Black02Z's Avatar
i was worried that if there is still some lower octane it would mix and be worthless
Old Nov 23, 2004 | 05:49 PM
TroubledWine's Avatar
I'd suggest driving it to the lowest fuel amount you can without running out and then filling it up with 92/93 octane(whatever your state runs) with an octane booster. That should be all you'd need to do to "switch it over".
Old Nov 23, 2004 | 05:55 PM
Black02Z's Avatar
kool thanks for the info
Old Nov 23, 2004 | 05:56 PM
Jay-Roll's Avatar
I say the next time you drive up to the pump just put the higher octane in it. I can't imagine regular octane would cause a problem. The owners manual says for "optimum" performance use highest octane possible. It doesn't say it's required.
Old Nov 23, 2004 | 07:48 PM
OBE1 95Z28's Avatar
Octane booster is snake oil, a waste of money. The car was designed to run 91+ gas, low octane gas would generate knock. Hopefully the knock sensor has been taking out timing to prevent valve/piston damage. If she didn't drive it hard, it's probably fine. I'd fill it with 91+ and not beat on it until you run through that gas and get a full tank of good gas.
95chwagon
Oct 16, 2015 12:24 PM
MDZ28
Sep 7, 2015 09:16 PM
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
TGGodfrey
Aug 18, 2015 06:08 PM
