GMMG I-Pipe Prob. - Pls Help
Hello,
I purchased a used GMMG exhaust over the weekend and I'm trying to install it on my LS1 'vert. I've run into the following problem: The I-pipe does not slide over the Y-pipe because the I-pipe is pinched where the band clamp was tightened during the last installation. I’ve tried to use a C-Clamp (in a reverse type of fashion) to widen the opening, but couldn’t get it deep enough to effect the pinch. Could an exhaust shop fix the pinch so the I-pipe will slide over the Y-pipe? How much would that cost?
On a side note, I noticed the I-pipe has a DYNOMAX sticker on it. Is it possible to purchase a replacement? Does the DYNOMAX I-pipe fit the GMMG exhaust without any modifications required?
Thanks for any replies!
Re: GMMG I-Pipe Prob. - Pls Help
you sure it's a true GMMG??
it should be stainless i think...and a dynomax pipe would be aluminized not SS.
you may have gotten suckered...depending on how much$$ you paid
I've been told by the former exhaust owner that the part that is pinched is a DYNOMAX 3" I-Pipe.
http://store.summitracing.com/partde...5&autoview=sku
Does anyone know if this would fit a stock y-pipe? Can I pick this up at a local store? (Note: I called Advance Auto Parts and the guy couldn't find it in the computer)
Mystery Z28
Oct 20, 2002 11:35 AM
