GM Power Window Replacement Motors - Bolts or Rivets
Old Apr 21, 2007 | 01:33 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Do the GM replacement motors for the windows come with bolts or rivets? I thought I had read somewhere that the replacement motors come with bolts, but the guy I'm getting it from thought they came with rivets, but wasn't sure. Anyone know the answer? This would be for '94.
Old Apr 21, 2007 | 01:57 PM
2001NBMZ28's Avatar
Don't know about the GM ones, but the ones from parts stores I've seen came with bolts/nuts. If it comes with both I'd use the bolts anyway, won't have to drill rivets again.
Old Apr 21, 2007 | 03:31 PM
Ages ago, my GM motor came with bolts. (At least, I think it did. It may not have come with anything) I know it did not come with rivets.
Old Apr 21, 2007 | 03:52 PM
94_PatriotRed_Z's Avatar
the ones from autozone with a lifetime warranty come with bolts/nuts
Old Apr 21, 2007 | 08:01 PM
BTC's Avatar
BTC
Thanks for the info. I wonder if the GM motors are better than what I could get at Autozone etc. I know they are more expensive.
Old Apr 21, 2007 | 08:14 PM
2001NBMZ28's Avatar
Well, I bought two supposedly new GM window motors off ebay from a store, both worked - but one was noisey and one wasn't, and neither came with bolts or rivets. My advice is to get one locally, if you have a problem with it you can return it for another one while the door panel is still off.
Old Apr 22, 2007 | 07:28 PM
Dave '97 Z28 M6's Avatar
I replaced mine with GM parts, ordered from a GM dealer, about 3 years ago. They came with bolts.
Old Apr 23, 2007 | 11:37 AM
Bud M's Avatar
Regardless what it comes with, use screws and nylon locknuts
Old Apr 23, 2007 | 03:22 PM
BTC's Avatar
BTC
Are the GM units better than what is available via Autozone etc.? I know they are a little bit more expensive.
Old Apr 25, 2007 | 04:20 PM
TobyZ28's Avatar
A few years back i replaced my motor and i can verify with 100% certanty it came with nuts and bolts for securing it in place. I had to drill out the stock rivets though.
Old Apr 25, 2007 | 10:07 PM
bombebomb's Avatar
I replaced my less then 8 months ago, came with bolts and nuts from the gm dealership (even though it was acdelco).
Old Apr 25, 2007 | 10:09 PM
Use shoebox's guide if you need the ultimate reference:
http://shbox.com/page/windowmotor.html
Old Apr 25, 2007 | 10:11 PM
OutsiderIROC-Z's Avatar
I can not see using rivets to put a new window motor in an F-Body when it is just gonna hafta be replaced again down the road.
HectorM52
Jul 30, 2017 11:46 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
MilkyClr69
Jul 29, 2002 10:01 AM
