Gatta replace the Positive Battery Terminal
Old Mar 12, 2007 | 10:12 AM
Need4Camaro's Avatar
My Battery recently died and when I went to remove it, I stripped the bolt nearly instantly, Kept messing with it and a piece of the battery came out WITH the terminal. Basically since the battery was leaking acid, it fused the positive receptor to the positive terminal, I tried to remove it but it ain't budging so I had to cut the entire terminal out... How hard is it going to be to replace the terminal as I've never done this before... What do I need to do?
Old Mar 12, 2007 | 10:33 AM
smithtim's Avatar
shouldn't be that hard just either follow the wires back and repalce the stock wiring or should be able to just cut the main hot wire and the battery and crimp on a new terminal.. just make sure you leave enough slack so it can still reach the battery
Old Mar 12, 2007 | 10:59 AM
Reason I was asking was because it LOOKED as if the stock wiring was sautered onto the terminal... I rarely touch anything electrical, Can I use chan-locks to crimp the wire onto the terminal? Also there's 3 wires that go into the positive terminal, I wanted to make sure that it was okay that all three of them touched...
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
silvermansteve
Mar 4, 2015 05:02 PM
nosliw
Feb 7, 2015 01:30 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Lions3
Aug 6, 2002 05:33 PM
