Gas gauge
Gas gauge
I have a 94 z28 and would like to know how to fix the gas gauge it doesn't work at the moment I got the car like that I change the fuel pump and chouldnt figure out what parts I need for gas gauge or do I have to go in the dash?
Re: Gas gauge
This will help isolate to either the sending unit/tank end or wiring to dash/guage end. Going to have to get under it w/an ohm meter. Ref shobx.com 4th Gen LT1 F-body Tech Articles
Re: Gas gauge
The float level sensor is part of the fuel pump support assembly. The wiring goes through the same harness connector as the fuel pump. Would have been ideal time to check it all out while you were changing the fuel pump.
Re: Gas gauge
Welcome to CamaroZ28.com!!
See if this helps, courtesy of Shoebox - Same article linked in post #2, above:
NUR2S
May 29, 2015 03:52 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
