front turn signal bulb 1994 z28
ongoing problem that i should definitely address, what's the front turn signal bulb number for a 1994 camaro z28? i've gotten very contraindicating info from the web, and autozone told me they were 3057. i put the 3057 in, bulb flashes with the hazards but not when i signal left. now i'm hearing its a 2057 or a 2397...help please?
Re: front turn signal bulb 1994 z28
sorry i didnt put a 3057 in, i put a 1157 in, and now its doing what i stated earlier, with it blinking with the hazards on but nothing with the turn signal on. so 2057 it is then? or 2397?
Yep.. Here's how if you want the details.. The light blue (left turn indicator) wire goes to pin H of the Turn/Hazard Switch Assembly. Internally in the assembly the wire goes to two places one is the turn switch contact and the other is the hazard switch contact. In normal mode the hazard switch sends +12 v to the turn switch and the turn switch sends the turn flasher signal to the light blue wire. In hazard mode the hazard switch kills the +12 v to the turn switch and puts the hazard flasher signal on the light blue wire (actually all four blinker wires). So a defective or burnt contact in the turn circuitry side of the assembly can kill one blinker in turn mode , but it will work in hazard mode.
94z28jbw
Sep 8, 2002 03:22 PM
