Fog lights to high beams?
Old Jan 22, 2007 | 04:55 PM
rickjames343's Avatar
Can I buy a set of high beams for a 93-97 and swap them with the fog lights? Is it just a simple swap?
Old Jan 22, 2007 | 05:13 PM
teke184's Avatar
do you just want a brighter fog light??
there are some lights on the market that will bolt up with minor mods to the brackets that are as bright or brighter than the headlights.
try the appearance section
Old Jan 22, 2007 | 05:58 PM
I don't really want brighter FOG ligts, I want brights in place of them. just so i could have more lighted road with the lows and highs (swapped with the fog lights)
Old Jan 22, 2007 | 08:24 PM
Stephen 87 IROC's Avatar
Are your fog lights wired separately? Normally fog lights will only work when the low beams are on and driving lights will only work with high beams.
Old Jan 22, 2007 | 08:26 PM
I realized earlier that when your brights are on, the low beams are too. That's basically what I wanted, so it defeats the purpose. I'd love the have the fogs as highs and wire them so that they on on when the brights are.
Old Jan 22, 2007 | 08:49 PM
94_PatriotRed_Z's Avatar
there is a way to wire the fog lights to stay on while the high beams are on. I have seen a write up on it before but cant find it agian
Old Jan 22, 2007 | 09:14 PM
That would be AWESOME if you found it
Old Jan 22, 2007 | 09:38 PM
LT1 POWR's Avatar
http://www.fbody.com/tech/details.cgi?id=9
Old Jan 23, 2007 | 12:35 PM
Thanks alot! On the subject of headlights, is there a way to turn off the auto headlights?
Old Jan 23, 2007 | 04:16 PM
LT1 POWR's Avatar
http://www.fbody.com/tech/details.cgi?id=61
Old Jan 23, 2007 | 04:48 PM
Capn Pete's Avatar
To disable just the "automatic headlight" feature, you pop up the big plastic dash pad, find the light sensor (not the alarm LED) and either A) unplug the sensor, and use a paperclip or something to join the 2 terminals together, or B) cut the wires, and splice them together (on the car side, of course).
That makes the car "think" that it's daytime all the time, and therefore, no "auto" headlights . I did that, as well as the fog-light "fix" within about ~2 weeks of owning my car, and I've never regretted it once .
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Brake_L8
Jan 20, 2015 09:44 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
siguy
Nov 27, 2014 10:07 AM
