Fog Lights
Old Apr 22, 2008 | 10:34 PM
94 Camaro Z-28's Avatar
Fog Lights
I am trying to replace a fog light on my 94 Z-28. What I want to know is do I need to change the light like I do the headlights or do I remove the lens cover from the fog light and change the bulb inside?
Thanks,
94 Z-28
Old Apr 22, 2008 | 11:00 PM
TeamingTealZ28's Avatar
You have to take the fog light housing off the bracket and unplug the bulb.
Then remove to bulb from the housing, its a 885 bulb.
Then plug it back in and put it back on. and ur done
Old Apr 23, 2008 | 11:18 AM
TRICK95's Avatar
I removed mine from the rear (it turns to the left), and replaced it. It was a PITA to get to initially, but once you get up and in there, nothing to it.
Old Apr 23, 2008 | 05:07 PM
likittysplit's Avatar
Does anyone make an OEM style replacement fog light? Both of my lenses are cracked and we all know that you can't get just the lens. I'm not even sure if you can still get a new assembly from GM.
Old Apr 23, 2008 | 06:41 PM
SNOTGREEN's Avatar
Wow, ur from Lex Park? So am I, never seen ur car around. I have the snotgreen colored z28. Anyhoo, I would try brandywine, they're local, and apparently have a ton of cars sitting around, they're due north of us. Hit me up on PM if you frequent the track or need LT1 help, I'm here for another year or so.
Old Apr 23, 2008 | 06:49 PM
snot green for life!!
I call it KAWI GREEN!!
Alien
Jun 27, 2015 01:13 PM
PROJECT X
Apr 17, 2015 12:13 AM
Jlo
Feb 3, 2015 09:41 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
