Fog Lights
Fog Lights
I just got myself a Camaro. Thank you, thank you! BUT, in VA you have to get yearly inspection on your vehicles. I did mine but the mechanic said that the fog lights did not work. What brand other than stock lights should I get and do the fog lights come on when the headlights turn on?
Re: Fog Lights
Not sure of a brand other than stock, but fog lights should not be part of the inspection process. I hope they didn't fail you for that?
The fog lights come on when you turn the fog light switch on, if the parking lights or low beams are on. They will turn off when you switch to high beams.
Thomas.
Thomas.
Re: Fog Lights
As for aftermarket Hella 75s' http://www.rallylights.com/hella/ff075.asp are the best from what I read....
Search the Appearance Section.....
For inspections, check your state laws.....
Brake_L8
Jan 20, 2015 09:44 AM
