Firebird gauge cluster ?
Old May 5, 2003 | 09:50 PM
CODY BEHNKE's Avatar
Will any of the 1997+ clusters work without problems?
Old Mar 30, 2004 | 06:20 AM
Live for TAs's Avatar
TTT on this, I'm interested in adding a 1997 cluster to my 1995 TA so I can convert to the 200 MPH speedo. Anyone done this or know if it is possible?
Old Apr 22, 2004 | 05:44 PM
99TransAmWS6's Avatar
Cody Check your PMS
Old Apr 22, 2004 | 11:42 PM
craigffb's Avatar
Yes a 97 cluster will work in an older car. I have one. I have a 94 and the only problems I have are the TCS light stays (I don't have TCS) on and the seat belt indicator does not go all the way out when I put my seat belt on, it just dims a bit. But it must be out of a 97, an LS1 cluster will not work.
Old Jan 4, 2009 | 03:47 PM
marc1130's Avatar
I have the same problem with the seatbelt light. Is there any fix, I'm thinking it is because diodes are used instead of lightbulbs and there is a BCM in the 97 model, where as we have an audio alarm module
Old Jan 4, 2009 | 04:01 PM
craigffb's Avatar
Not that I know of. I've had mine in my car long enough I don't even pay any attention to it any more. I did cover the TCS light spot with a piece of electrical tap, so it doesn't show anymore.
Old Jan 4, 2009 | 10:55 PM
IPrice's Avatar
Why don't you guys remove the cluster and take the light bulb out that makes this useless reminder go away for good????
That's (not) what Brian Boitano would do.
-Ivan
Old Jan 4, 2009 | 11:03 PM
neil350's Avatar
1994-1996 can use the 97 clusters, 93s are screwed like always, the tach wont work past 2K rpm.
Old Jan 4, 2009 | 11:05 PM
craigffb's Avatar
-Ivan
They aren't bulbs. They are diodes soldered to the board.
Old Jan 4, 2009 | 11:07 PM
Gtpguy's Avatar
What happens to the mileage? Does the 97 gauge cluster (digital ode) read it from the PCM?
Old Jan 4, 2009 | 11:10 PM
craigffb's Avatar
Mileage is stored in the cluster. Find something close or get it reprogrammed. Not sure who can do it.
Old Jan 5, 2009 | 12:04 AM
marc1130's Avatar
-Ivan
Yeah I'd have to tape it off, it's an LED, which is why I think it stay's on. I'm getting this idea that the older bulb versions send two 12volt signals in opposite current directions to shut off the bulb. With the LED it is biased in one direction therefore it is always on.
Theoretically 96 cars should not have this problem because they use the Body Control Module rather than the Audio Alarm Module to control the seat belt indicator.
I was thinking of taking the spare '97 v6 gauge cluster board I have laying around and soldering a bulb in place of the LED to see if it fixes the problem, if that works I will modify my '97 155mph v8 cluster.
Another fix would be to rewire the interior to accept the body control module from the later 96-97 f-bodies, not worth the effort.
Old Jan 5, 2009 | 07:35 AM
MTBSully's Avatar
good idea. I have had two 95s before this and the 97 dash looks 10x better then the dashes of previous years.
nosliw
Apr 27, 2015 04:01 PM
mattstrike
Mar 11, 2015 07:33 PM
Joes96z
Dec 13, 2014 07:48 PM
CaRParts102
Dec 6, 2014 08:45 AM
