express down module
express down module
Will a bad express down module cause the drivers side window to stop working completely.
I put a brand new motor in and got no movement. However, over the past two weeks I have noticed the window motor was dieing as it would not go up all the way the first time. It took about 3 shots at it until it made it up completely. Could it be the express down module now too? Or did I just possibly do something wrong?
P.S. The window was automatically going down just like normal prior to the motor dieing.
If the motor is new and you can put power directly to it and it works fine then the problem is either the switch or the factory express down module.
Test the switch with a Meter and make sure its good.
You can pick up a driver side kit from our site that will come with a new improved express down module for about the same price as just replacing the module.
Sep 18, 2015 03:46 PM
