Exhaust size to get
Old Sep 1, 2006 | 12:49 PM
micfly83's Avatar
Exhaust size to get
Hey yall
I still haven't gotten a strait answer, maybe this section will be better.
I'm gonna be puttin a cutout on my 95 z28, but the only sizes are 2.5" and 3".....i'm not really sure which one o go with.
Also I think i'm gonna lose the cat, and put in a strait pipe with the cutout.
So I just need to determine which size to go with - small or big.
Old Sep 1, 2006 | 12:52 PM
WS6NIGHTMARE's Avatar
Re: Exhaust size to get
3" is more than enough. If you need more than that you must have some serious power.
Old Sep 1, 2006 | 12:59 PM
micfly83's Avatar
The car is stock...
1995 Z28 M6
Future mods are just a CAI, bigger TB, and short throw...nothing serious.
Old Sep 1, 2006 | 01:12 PM
Ya, 3" will be more than enough. Start with a catback of your choice, or bolt up a whole new exhaust altogether. I wont give my suggestions because then the opinions go for days.
Old Sep 1, 2006 | 01:18 PM
micfly83's Avatar
Well I plan on keepin the stock muffler for now
Just basically takin out the cat...fillin in the section with a 3" pipe I guess and then fitting up the Y-pipe for the cutout where the strait pipe is.
Is this a good location for the cutout?
Old Sep 1, 2006 | 01:38 PM
teke184's Avatar
stock pipe diameter is 2.75"....so you wouldn't want to put a smaller diameter cutout in...
so 3"
and putting the cutout right under the front seats is not going to be very enjoyable, unless you plan to use it ONLY at the track. a better place is about 3ft back just before the I-pipe goes up over the axle. there is even a small indentation that allows the cutout to tuck up nicely.
personally i would pull the cat, put a piece of 3" straight tubing from the end of the Ypipe, back to a cutout. and then the stock pipe from there to the muffler.
that way when the cutout is open you get full effect of the 3" cutout. and it's less welding than putting a pipe in for the cat and then a cutout 2ft behind it...ie...cheaper. 3" tubing is cheap
Old Sep 1, 2006 | 02:28 PM
micfly83's Avatar
so 3"
Would the noise level be any different from having it right after the Y-Pipe from the exhaust manifold or having it right in front of the axle...
Old Sep 1, 2006 | 04:17 PM
teke184's Avatar
it will probably be worse having it farther forward
Old Sep 1, 2006 | 06:53 PM
micfly83's Avatar
Yea it would probably have a better note if it had more piping to go through.
Old Sep 2, 2006 | 09:01 AM
teke184's Avatar
not so much that, it's the location being farther away from the passenger. having it roar right under your feet and reverberating off the pavement and the front seat floorboard would be horrible.
in the back it pushes the sound out away from you more and there is more to insulated the sound....less floor board space, gas tank, seats etc...
Old Sep 4, 2006 | 07:43 PM
CamaroRacing12's Avatar
wat about with longtubes? put the dual cuouts right after the longtubes for an open header effect.....? wat u guys think about that?
Old Sep 4, 2006 | 07:46 PM
mattybz28's Avatar
Like i said in your other post, don't do it. It'll sound like a destruction derby station wagon.
Old Sep 4, 2006 | 08:07 PM
wat about if they flange out?
Old Sep 4, 2006 | 08:36 PM
micfly83's Avatar
Why would it sound bad?
All the cars at the drag strip with cutouts sound insanely awesome.
Old Sep 4, 2006 | 08:52 PM
thankyou micfly i totally agree! thats why im gonna do it! if it sounds bad (which i highly doubt) i can always remove them and replace with straight pipe
