Exhaust to loud for DE inspection, any quick fixes to temp quiet it down?
Old Feb 1, 2006 | 08:54 PM
SupermanSS's Avatar
Took the car through DE inspection and for the first time EVER had the guy test the db level of the exhaust. It was 100.4. Anything I can do to temporarly quiet it down, to get it to pass that doesnt involve removing the entire exhaust?
Old Feb 1, 2006 | 09:01 PM
sabre81's Avatar
Re: Exhaust to loud for DE inspection, any quick fixes to temp quiet it down?
Summit sells exhaust inserts that are supposed to quiet things down. I don't have first have experience though so many someone else will chime in.
Old Feb 2, 2006 | 04:08 AM
DaddySS's Avatar
The car chemistry inserts are a great way to tomporarily quiet the exhaust. Insert it just before the I pipe and it will make a big difference. The two disc unit should be more than enough.
Old Feb 2, 2006 | 09:32 AM
SupermanSS's Avatar
Thanks for the info guys. I am going to try them out more than likely, unless i can think of anything else.
Old Feb 2, 2006 | 10:05 AM
Kraest's Avatar
Retired
Stick a potato in the exhaust pipe.
Or you can be like those 70s Ford pickups and use 1-1/2" plumbing pipe for dual exhaust.
Old Feb 2, 2006 | 07:56 PM
Ellis's Avatar
Wink Re: Exhaust to loud for DE inspection, any quick fixes to temp quiet it down?
When I was involved in Formula SAE, we had to comply with dB requirements. Our car failed (miserably). To get it to pass we stuffed steel wool in the exhaust for the dB retest. Worked fine for quieting the engine, but the wool blew out very easily (steel wool, fresh from a visit to your exhaust system internals, will hurt like hell when it suddenly pops out and stickes to your leg; curse loud to aleviate pain). You'd have to do something to keep it in place until you got through the test.
Old Feb 2, 2006 | 08:01 PM
pHEnomIC's Avatar
I know that they have something called the cone of silence in some ss exhausts. http://ls1sounds.com/pics/SLP/cone_of_silence.jpg
MAybe you can jam something in there that shape and it will quiet things down a bit. If you have a hypertech, lower your rev limiter temporarily so they cant take it so high.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
