Engine removal. Brake lines? Help fast!
Old Oct 4, 2006 | 11:43 PM
96ZCamaro's Avatar
Ok well I got the whole motor ready to come out. Only thing holding me up is these dang brake lines. Now I have have the abs crud and all that. What is the easiest way to go about doing all this with these brakes? I need to know by tomarrow, cause tomarrow after work she's comming out.
Old Oct 5, 2006 | 01:02 AM
Z95m6's Avatar
Re: Engine removal. Brake lines? Help fast!
you need to be alittle more clear on what you're doing. I assume you're going out the bottom correct? If so have you unhooked the ABS unit and removed it? Have you been following any of the guides that can be found on this site. I have done mine twice now out the bottom and there is a guide i've posted before that has exactly everything you need to do listed in it.
Old Oct 5, 2006 | 06:52 AM
Disconnect the brake lines at the ABS unit and fish them out as you drop the engine down. You may have to tweak them a little-just take it slow.
Old Oct 5, 2006 | 11:30 PM
96ZCamaro's Avatar
Ok well I'll just disconnect all the lines at the abs unit and go from there. I didnt get to get to it tonight though due to unforseen circumstances. But thanks for your guys input. Any other tips would be great. Also yea I am doing it out the bottom.
Old Oct 6, 2006 | 09:16 AM
Dave89IROC's Avatar
don't have to undo all the lines, just the two to the front brakes
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
