Engine harness Repair
Hi guys,
The wiring harness in my car is in need of some repair; i'd like to re-do the fuse-block to make it smaller, remove un-needed wires and make it look more attractive for my engine bay. There's a horrible tangle going on right now.
What are some replacement loom brands/products that you guys have used to make your engine bays sparkle? Any other tips or tricks that you could recommend?
Thanks!
Thanks!
Not having reached that part o my rebuild, I have yet to pick out exactly what I'm going with. But I do like the look of the woven high-temp looms for the engine bay. EFI Connection sells harnesses and connectors for some stuff and they even have the color coded wire if you choose to rewire things with the correct OEM color/stripe combo.
Re: Engine harness Repair
There Are many different types of split loom out there. There are even not split varieties which just expand and contract. I imagine for our cars we would need to us split loom due to the large connectors at the PCM. What do you think?
Jan 5, 2015 07:14 PM
