Either blinker or running light works
Had a burnt out tail light/blinker and replaced it, but the blinker still didnt work. So I installed a new flasher. After installing the new flasher, if I have the bulb in one way the blinker will flash, if I turn it 180 then only the running light will be on. What could be causing this?
It might be the tail light socket.... Its a 2 part plastic piece with die electric grease squeezed into it.... In mine the grease was dry and flaking, and the internal connection were rusted... Cost around 10~15 dollars at the dealership, but does not come with the die electric grease.. You can pick some up at a local part store, or buy at dealership.. Costs vary..
DO NOT use regular grease......
I believe this is the part .. GM PART # 12003759
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $22.40
OUR PRICE: $11.65
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $22.40
OUR PRICE: $11.65
fpete1992
Dec 11, 2014 03:51 PM
