Driveshaft interchahge
94 M6 Driveshaft interchange
Will a shaft from a 89 V6 auto work in a 94 M6? I think it will but I'm not sure. I chucked my drive shaft yesterday and need something FAST. Found THIS on Ebay and wondered if it would work for now.
Re'
Re'
Re: Driveshaft interchahge
all driveshafts are interchangable from 83-02.
only thing i'm not sure of is if extra brackets are needed for the 2 piece driveshafts from the 4th gen v6 cars.
if he already broke one....i think all this one is for is so the car can be driven.
sounds like you need to buy a good aftermarket shaft...like one from denny
I wish I broke it from too much HP. It actually came apart because one of the bolts on the yoke backed out. That will teach me to recheck them after a few days. I installed the new rear 2 weeks ago and had been meaning to get under there and check all the bolts.
all drivesahfts are interchanageable, not sure if 3rd gens had 2 piece or 1 peice.
If you get a 2 piece from a 3rd gen, you will need the torque arm as well, the center swing bearing bolts into the torque arm.
Get a steel one before you even think of gong to that hassle.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
