Okay...neither has the car for the past six months. Just haven't been driving it. Anyway, when I try to roll the ds window down nothing happens. Just a clicking sound from the express down module. The ps window does like it always has from the ds door switch. Could the module be screwing it up?
You can always check to see if power is getting to the window motor or apply power and ground to the motor to see if it moves, but sounds like the typical dead window motor.
I will try that before I remove the the motor for sure. I hope it's the motor and not a gremlin...lol. I replaced it a couple years ago, of course using your great How-To.
Quote:
RAP is part of the BCM on a 1996. I would first check to see if you are getting power to the window circuit breaker, then the switch(es), then the motors.Originally Posted by fastcam91
Both of my windows wont go down at all. Kind of weird that they both dont work. Just got the car not too long ago. Could it be the RAP? and how would I check if it is or not?
If your stereo doesn't work while the windows don't work it's probably the BPM.
