Drive Power window works sometimes
Old Apr 27, 2008 | 02:07 PM
saevelland's Avatar
The driver side power window works sometimes and goes out randomly. When not working the relay clicks. And it doesnt line up right. Any one know what the problem is.
Old Apr 27, 2008 | 02:32 PM
Could be the window motor or something in the window mechanism that is binding or broken("doesn't line up right"). Probably going to need some inspection with the inner door panel removed.
Old Apr 27, 2008 | 02:37 PM
saevelland's Avatar
we all ready tool evey thing off some of the fiberglass wher the window motor atached to is gone so the motor isnt lined up right. I dont know how i would go about fixing the fiber glass.
Old Apr 27, 2008 | 04:32 PM
Fiberglass patch kit.
Old Apr 27, 2008 | 10:09 PM
saevelland's Avatar
will do. And i figured out it wasnt a fuse. Mustve been the motor. Any suggestions on what brand to buy for repair kits?
Old Apr 28, 2008 | 05:45 AM
SpeedDemon02SS's Avatar
autozome is cheap, about $60 if i remember correctly. And they have a lifetime warrenty. dealership runs around 170, but you can also try gmpartsdirect.com if you want factory. I just checked, it is 87 plus shipping. but no lifetime warrenty.
Old Apr 28, 2008 | 05:16 PM
saevelland's Avatar
For the window motor?
Old Apr 28, 2008 | 05:21 PM
Red93Camaro's Avatar
I have the same problem! when I press the button on the the door to have my passenger side window roll down...sometimes it works sometimes it doesnt...Is it the switch? or the motor? I know on the drivers side the window goes up really slow...and stops half way...then I have to wait and Do it again to get it down completely. Any help here?
Old Apr 28, 2008 | 06:48 PM
ss.slp.ls1's Avatar
Sounds like you need a new motor.
Old Apr 28, 2008 | 07:20 PM
Thats it? nice, Thats not a problem at all...I thought it was all electronic buttons and stuff...
Old Apr 30, 2008 | 11:15 AM
autotrix's Avatar
I have seen cracked driver side window switch causing intermittent electrical issues like what you are experiencing. I would check voltage at the passenger window while pressing the switch and wiggling it and see if it cuts out. 9 out of 10 times it is just a motor, but you never know! Keep us in mind when replacing that passenger side window motor.
Old Apr 30, 2008 | 11:24 AM
Yes, that was the price of the window motor.
Also, look at what autotrix said, I had that issue too. The cover to the switch was cracked on one side, making the connection a bit intermitten.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Snoman73
Nov 17, 2014 07:22 PM
Lions3
Aug 18, 2002 11:12 AM
MilkyClr69
Jul 29, 2002 10:01 AM
