Downshifting/Compression Braking
Old Dec 26, 2005 | 09:52 PM
slayer6x6's Avatar
Are there any long term concenquences from downshifting to slow down your vehicle? Im not talking about jamming it into first at 50. But just normal downshifting to a redlight, maybe bringing it up to 3500-4K and just running down the gears?
It should save you some life on your brakes, and it just sounds cool!
Old Dec 26, 2005 | 10:02 PM
Re: Downshifting/Compression Braking
Engine braking from high RPMs is hard on the tranny clutches. Brakes are much cheaper.
Old Dec 26, 2005 | 10:14 PM
cjmatt's Avatar
i assume youre talking about on an automatic. On a manual transmission car itll wear down synchros and clutch if you dont know what youre doing, you have to rev it to the rpm at which itd be if it were in the lower gear and then let the clutch out, shouldnt hurt the transmission.
Old Dec 27, 2005 | 08:55 AM
TraceZ's Avatar
Shoebox is right.
Brake pads are cheap and easy to replace. It's not worth any extra wear on the drivetrain components... and there will be extra wear. Even if you blip the throttle perfectly, you are causing wear on the throwout bearing, master cylinder and slave cylinder. All of these items are more expensive and harder to replace than brake pads.
If your car is auto, it is even worse for it.
Use the brakes, that is what they are there for.
Under normal driving conditions, I leave it in gear and coast as long as I can, use my brakes to stop and pop it in neutral when the RPMs hit 1000-1500.
I also do not ever sit at a red light with the clutch pressed in. It's hard on the throwout bearing to sit with the clutch pressed in.
Old Dec 27, 2005 | 09:39 AM
'99 SS's Avatar
Agree 100%...."USE THE BRAKES"!!!
I just read a story on an IROC in 'World Wide Camaro'. The guy has over 200K miles on the car, and replaced his brakes once, while replacing the clutch 3 times...when asked how he went thru 3 clutches to 1 set of brakes....engine braking.
Old Dec 27, 2005 | 03:43 PM
wrd1972's Avatar
I have wanted to ask this question for a long time.
Thanks guys
Old Dec 27, 2005 | 05:00 PM
slayer6x6's Avatar
Wilwoods aren't cheap either!!!
I guess not more expensive than drivetrain components though.
Old Dec 27, 2005 | 11:01 PM
Bayer-Z28's Avatar
I was allways told... which would you like to replace more frequently? The brakes or the clutch.
I use the brakes more than I decell. But, my T6 doesn't like to downshift to 2nd.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
