door vapor seal- is it needed?
Old Jan 27, 2018 | 09:37 PM
scottpdx2010's Avatar
hi, and thanks in advance for your help.
i have a 1996 firebird. someone in the past removed the door vapor seal.(the plastic behind the door panel.) it has been missing for a long time. how important do you guys think it is? also is there a decent way to replace it if needed?
i was thinking of just some 10 mill visqueen and some adhesive, or should i try to find the oem, or just forget about it? also open to other ideas.
thanks again for your thoughts
Old Jan 27, 2018 | 09:58 PM
GaryDoug's Avatar
Prominent Member
Re: door vapor seal- is it needed?
It's just a clear plastic. I would use something from Home Depot or Walmart in a heavy weight type. It's originally stuck on with a putty-like substance but use any method that works.
Old Jan 27, 2018 | 10:08 PM
thank you , but can i ask how important is it? and do i need it???
Old Jan 27, 2018 | 10:19 PM
GaryDoug's Avatar
Prominent Member
I guess that depends on how good the rubber window seals are. Some water will get inside anyway. It's cheap to do, so why not keep the water off the inside panel? You don't want things growing in the cardboard and insulation materials.
Old Feb 2, 2018 | 03:39 PM
Zspoiler's Avatar
It depends on what time of year you drive your car.The moister barrier keeps the moister out of car. Moister means rust. Then you go from there.
z28beast
Apr 4, 2010 12:37 AM
Stealth Z
Feb 28, 2003 08:26 PM
jannes
Classic Engine Tech
10
Aug 18, 2002 08:59 PM
ws6gta
3rd Gen / L98 Engine Tech
Jul 3, 2002 05:12 PM
ZDADDY92
Jun 10, 2002 09:15 PM
