Does heavy-duty headlight harness= brighter lights?
Old Dec 15, 2006 | 02:23 PM
BradcTA's Avatar
I'm using Luks hi wattage 80/100 bulbs in my lows/ highs and there not melting or anything but the highs are a little dim/yellowish and I was wondering if this was an implication that they weren't giving enough power and if an upgrade harness would make any difference.
Old Dec 15, 2006 | 03:21 PM
Jumper some juice directly from the battery and see. If it helps, rig up a relay system to provide direct power to the lights.
Old Dec 15, 2006 | 03:26 PM
BradcTA's Avatar
OK, I'll try that. If it helps, I'll ask how to set up a relay system.
Old Dec 15, 2006 | 07:28 PM
Camarocracy's Avatar
The heavyduty wires allow you to run the brighter bulbs without melting your light switch system.
Old Dec 16, 2006 | 01:44 PM
BradcTA's Avatar
So if it doesn't melt with the standard wiring, I'm OK?
Old Dec 16, 2006 | 01:57 PM
IROC-T's Avatar
Try cleaning your headlight grounds also. If you don't have good groud you won't have bright lights.
Old Dec 16, 2006 | 03:20 PM
Dave89IROC's Avatar
not neccesarily, the stand alone harness allows for brighter lights by eliminating the voltage drop through the headlight switch and wiring, by using relays and heavier wiring, along with moch shorter runs of wire
Old Dec 16, 2006 | 09:05 PM
AlfredB18's Avatar
Ask this guy...I think he even has a schematic and suggestions for a theoretical harness design linked on his main page...
danielsternlighting.com
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
