disconnect a/c clutch, or??????
Old Jun 26, 2005 | 04:34 PM
sobracing's Avatar
I'm pretty sure my a/c pump is bad ( when i turn on the a/c the pump is really loud, but blows cold air) anyways, when I try to run the heater it does the same thing...why would the a/c pump enguage when the heat is turned on? OR could it not be the pump and maybe something else that is wrong? A/c being broken is not so much a problem...foggy windows in the morning is a much bigger issue.
As always, any help is appreciated
Old Jun 26, 2005 | 05:21 PM
rngilliland's Avatar
Re: disconnect a/c clutch, or??????
If you are on defrost the compressor runs to help dehumidify the air even if the temp is on high. If you are set on heat only then the compressor shouldn't run. Listen to it outside the car with the compressor off and then have someone turn it on. You should be able to tell if the noise is from the compressor or something else.
Old Jun 26, 2005 | 10:11 PM
sobracing's Avatar
i'll check that out. I'm sure its the compressor making the noise. I cant remeber if I just tried the heat on defrost or not. Thats good to know though.
Thanks!
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
raroz28
Sep 8, 2015 06:10 AM
WPHIG2
Aug 27, 2015 06:37 AM
karpetcm
Aug 14, 2015 03:02 PM
