Difference Between O2 Sensors, front and rear?
Old May 16, 2004 | 02:03 PM
Flat_Tire_'s Avatar
I recently did a LT install and at the time I did not realize the front O2's were different from the rears. I've heard that mixing them up can cause a bank of cylinders to run dangerously lean. Is there a visual difference between the front and rear O2 senors? .. If there is I can check by unscrewing my rears (which are just plugging the rear holes in the Ypipe and not connected bcause I'm using O2 sims).
Thanks for the help,
Sean
Old May 16, 2004 | 04:55 PM
Z_28_0117's Avatar
I got the impression an O2 sensor is an O2 sensor with the only thing being different is the length of the lead. After headers I used the rears in the front because of the longer leads and the car runs rich if anything.
Old May 16, 2004 | 08:39 PM
Flat_Tire_'s Avatar
Cool that's what I thought too but was told otherwise.
If anyone else does think otherwise .. please post.
Old May 17, 2004 | 02:36 AM
94ZRiCeKiLr's Avatar
the only difference is the length of the leads.....after my headers, i swapped a rear into the front because the front was shot and the rear was just plugging up the hole in the y-pipe (i have O2 simms naturally)...anyway, it ran fine....
EDIT: the only possible difference is some O2 sensors are heated (the 4 wire kind) and some aren't (the 3 wire kind) but all 4 LS1 O2s are 4 wire...
Old May 17, 2004 | 03:58 PM
Flat_Tire_'s Avatar
Cool. Thanks.
Jazsun
Dec 29, 2014 12:14 PM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
