Did Underdrive Pulleys Kill My Battery??!!?!?!?
Old Aug 3, 2005 | 02:11 PM
MarcR94v6's Avatar
Did Underdrive Pulleys Kill My Alternator??!!?!?!?
So I was driving up to visit my friends in Irvine about an hour and a half away and my car starts acting weird. I get a check gauges light and my speedometer is acting jumpy. My voltage, which was already lower after I put on my underdrive pulleys crawled to nothing. So I pulled over to the side of the road and had to be towed home. Waiting in my car for an hour. Just got back. What do you think happened?
Old Aug 3, 2005 | 02:19 PM
MarcR94v6's Avatar
Re: Did Underdrive Pulleys Kill My Battery??!!?!?!?
Well my dad thinks my alternator is too slow and it doesn't get the 12 volts that it needs all the time, could I get a new alternator with more output? or do I have to put my old pulleys back on? I'm certain it was my alternator now.
Old Aug 3, 2005 | 03:20 PM
1997formula's Avatar
With the car running, put a volt meter on the battery, you should have around 14 volts, if the alt is charging correctly.
Old Aug 3, 2005 | 03:49 PM
Rice Killer87's Avatar
Buying a higher amp alt. might help,but yes the pullies are probably what caused this to happen.
Hopefully this didnt kill your battery completely and you wont have to get a new one. If its dead put a charger on it at low a amp rating,if that doesnt work the battery's cooked.
Good luck!
Old Aug 3, 2005 | 04:27 PM
87DJP2001's Avatar
My guess the underdrive pulleys are your problem. They are not worth the so called gains on a street driven car.
Old Aug 3, 2005 | 05:11 PM
V8 Slayer's Avatar
Ditch the pullies...
Old Aug 3, 2005 | 05:13 PM
myslowcamaro's Avatar
cant you run an underdrive pulley if you have an overdrive pulley for the alt? thought i read that before on here.
Old Aug 3, 2005 | 05:37 PM
87DJP2001's Avatar
Then what do you gain, the most screwed up thing you can do to your car.
Old Aug 3, 2005 | 06:12 PM
MarcR94v6's Avatar
$53 down the drain
Old Aug 3, 2005 | 06:25 PM
00Z28SS's Avatar
I've had my underdrive pulley for 4 years and haven't had a problem with it yet
Old Aug 3, 2005 | 06:42 PM
87DJP2001's Avatar
And how many miles have driven tin those 4 yrs?? four or five times down the track??
Old Aug 3, 2005 | 08:07 PM
pearlpurple's Avatar
underdrive pulleys will shorten the life of your battery,,, unless you put a lot of highway miles,, for yours it sounds that it is not just the underdrive pully as you state you were on the highway and the battery still dies,, check the battery but I would guess your alternator may be already out or on the way out.
Old Aug 3, 2005 | 10:24 PM
Brent94Z's Avatar
Super Moderator
I've had underdrive pulleys on my car for 100,000 miles. No issues with the battery.
Old Aug 3, 2005 | 11:30 PM
V8 Slayer's Avatar
I had mine on for like 50 miles and immideitly noticed voltage drops...Returned them.
Old Aug 3, 2005 | 11:39 PM
MarcR94v6's Avatar
Thanks for the help everyone, I'm getting a new alterntor reguardless. Yet another lesson learned .
